The new WPF 35 brine-water heat pump adds a further performance rating to STIEBEL ELTRON’s WPF line that is very popular on account of its high COP and low acoustic pressure. The WPF 35 satisfies demand by customers for a medium size in the WPF 20..66 line of powerhouses specifically for larger residential developments, commercial and industrial premises: it provides 38 kW heating output (at B0/W35) – and that with a COP of 4.73 (acc. to EN 14511).
The entire line of appliances now with six individual appliances with ratings of 20, 27, 35, 40, 52 and 66 kW can now be combined even better and more precisely to match individual requirements – even in cascade circuits.
The robust single compressor heat pump assembly also has safety devices like pressure switches and frost protection in addition to a scroll compressor and a high-grade steel plate heat exchanger. When the system is fitted with accessories and has been planned accordingly, the WPMW II heat pump manager allows active and passive cooling. Thanks to the sturdy housing, two appliances can be stacked on top of each other to save space. A fork lift truck or lifting rings are used to install the either indoors or, if protected against the weather, outside.
Heating Pump WPF 35 by Stiebel Eltron
- 13 May 2020 Позиция STIEBEL ELTRON: кризис, вызванный коронавирусом форсирует решение климатической политики
- 10 February 2020 STIEBEL ELTRON теперь совладелец представительства в России
- 22 March 2019 Новинки Stiebel Eltron на выставке ISH
- ЖУРНАЛ СОК Array Оптимальный бивалентный режим работы теплонасосных установок типа 'воздух-вода'
- 19 July 2017 Водонагреватели STIEBEL ELTRON в ресторане KFC
- 28 June 2017 STIEBEL ELTRON в Лужниках
- 5 June 2017 Stiebel Eltron в новом терминале Емельяново
- 30 May 2017 Stiebel Eltron снижает розничные цены.
- 23 May 2017 Семинар Stiebel Eltron в Новосибирске
- 17 May 2017 STIEBEL ELTRON в Казани.
