Spot checks on solar installations by MCS inspectors are increasing, with the installer having to cover the cost of re-inspection if the installation is sub-standard, according to Deks UK, the supplier of flashing products to the roofing industry.
In line with the Government's Microgeneration Installation Standards (MIS), all solar installations have to be carried out by MCS registered installers.
MIS 3001 2.1a for solar thermal and MIS 3001 2.1 for PV state that in 'all circumstances the building's weather tightness must be maintained. Holes sealed with mastic or silicone sealant are not considered durable.' The standard also emphasises that 'all roof penetrations (eg for the collector, pipe work, cables or bracketry) must be durably sealed using purpose made products capable of accommodating movement and temperatures to which they may be subjected.'
David Jones, divisional manager of Deks UK, said: "Many of the on-roof installations we see do not have appropriate seals around roof penetrations or protection for PV cables, creating problems for the future - or in the shorter term a serious risk of failing the spot checks we hear are currently being carried out by MCS inspectors."
He added: "If installers fail their MCS accreditation assessments or substantiated complaints are received, then the certificate holder is liable to carry the additional costs of re-inspection which at current daily rates will be an eye-watering minimum of £600 plus VAT."
NHBC Foundation research shows that an increasing number of roof leaks are being caused by faulty solar installations which could lead to reduced customer confidence in renewables.
Deks believes that lack of training or understanding how to carry out best practice weatherproofing of pipes and cables is more likely to be the cause than poor installation of the collectors themselves. Failure to adequately protect cables from damage can easily reduce the effectiveness of the system and create a possible electrical danger.
Mr Jones said: "Under the MIS regulations just because you may not have designed the system you are installing it doesn't mean that you won't be held responsible if the roof leaks. As an installer or sub-contractor you still have to be competent enough to review and verify that the design would meet the MIS standards set out, so lack of knowledge isn't a valid excuse."
"Responsibility for fixing solar panels often falls between two trades, roofers and plumbers. By using specialist flashings that have been designed for use with solar panels, fixing couldn't be easier and all of the problems created by DIY solutions are eliminated," he concluded.
Verification of Solar Installations in the UK
Открыта регистрация для участия монтажников в Международном строительном чемпионате С 1 по 4 октября 2024 года ...
TotalEnergies будет производить водород c помощью электроэнергии от офшорной ВЭС ВЭС мощностью 795 мегаватт (МВт) должна быть введена в строй в 2028 году ...
Sinopec планирует построить 10 тысяч солнечных электростанций к 2027 году Sinopec о реализации программы «Десять тысяч станций Мугуанг» ...
Плавучую СЭС запустили в Азербайджане В Азербайджане начала функционировать плавучая солнечная электростанция 'Беюкшор' ...
Китайцы планируют офшорный ветропарк мощностью 29,3 ГВт для снабжения Шанхая Шанхай сможет получать около 100 млрд кВт·ч зеленой электроэнергии в год ...
Bosch объявил о крупнейшей за свою 137-летнюю историю сделке Bosch провела крупнейшую в своей истории сделку на $8 млрд ...
В Норвегии построят «Ловца ветра» — огромную ветряную электростанцию Модульная конструкция ветроустановки позволит изменять мощность ...
У побережья Бельгии заработала первая в мире морская зарядная станция Зарядная станция установлена на подстанции ветряной фермы Nobelwind ...
Анализ размера рынка мембран обратного осмоса для сточных вод Региональный анализ и прогноз до 2028 года ...
Во Владикавказе открыли самую мощную электрозарядную станцию в России Станция вошла в Книгу рекордов России ...
1 вчера -
В МЭИ подготовили специалистов по разработке защищенных интеллектуальных систем энергетического устройства Состоялся первый выпуск слушателей ...
Новинки 'Сириуса' и ИЗТТ в числе лучших Продукция заводов ИЗТТ и «Сириус» представит Удмуртию в финале конкурса «100 лучших товаров России» ...
Тепловым насосам необходимы новые тарифы на электроэнергию Новые тарифы должны снизить финансовую нагрузку для домохозяйств ...
Проект популяризации электроотопления частных домов в Красноярске признан успешным Пилотный проект «Новое тепло» ...
С начала года в России число электромобилей выросло на 27% Проект «Электроавтомобили и водородные автомобили» ...
Утилизация мусора – не первый вид ВИЭ, который приходит в голову Однако именно на этот возобновляемый источник делают ставку во Вьетнаме ...
Новинка от BAXI – стабилизаторы напряжения BAXI Energy Новые модели BAXI Energy мощностью 7000 и 10000 ВА ...
1 24 July 2024 -
Ohmium заявила о запуске своего «гигазавода» по выпуску модульных PEM-электролизёров Цены на солнечные модули продолжают находиться на чрезвычайно низком уровне ...
ГК «ССТ» открывает «Академию электрообогрева» Новый образовательный проект Группы компаний «Специальные системы и технологии» ...
Власти Австралии одобрили проект энергомоста в Сингапур мощностью 1,75 ГВт Энергомост заработает в начале 2030-х годов ...
В Китае запустят первый в мире двухбашенный гелиоконцентратор на 30 000 умных зеркал Проект запустят к концу года ...
Солнечные батареи защитили от выгорания при помощи особых молекул Авторы разработки использовали самособирающийся защитный монослой ...
На Сахалине начали производство зеленого водорода Запущен в работу первый в России водородный полигон ...
В Китае установили самый мощный в мире прибрежный ветрогенератор Ветрогенератор будет производить 72 гигаватта чистой энергии в год ...
Бразилия стала лидером G20 по доле ВИЭ в структуре электрогенерации В среднем по G20 этот показатель составил 29%, согласно данным Ember ...
Объем рынка плавательных бассейнов вырастет на 7,43 млрд долларов США в период с 2024 по 2028 год Повышенный спрос на бассейны ...
К 2030 году рынок промышленных тепловых насосов принесет 15,86 миллиардов долларов США Среднегодовой темп роста 7,8% ...
Изменились требования к тепловой защите зданий Минстрой РФ опубликовал обновленный СП 50.13330.2024 «СНиП 23-02-2003 Тепловая защита зданий». ...
Подписка на новости отрасли
- 29.07.2024 11:00 - 12:00 Webinar Накопительные водонагреватели Philips. Обзор ассортимента.
- 30.07.2024 10:00 - 15:00 Seminar Отечественное оборудование ОВЕН для промышленной автоматизации
- 30.07.2024 10:00 - 16:00 Seminar Семинар по оборудованию Ariston в г. Казань
- 30.07.2024 10:00 - 12:00 Webinar Актуально о судебной практике, принятых и планируемых изменениях в законодательство в сфере ВиВ. Актуальные вопросы из обращений
- 30.07.2024 14:00 - 15:00 Webinar Как проверять на исправность компоненты традиционных котлов BAXI
- 31.07.2024 10:00 - 13:00 Seminar Лунда: Завтрак с поставщиком «CNP»
