New universal controller RWF5
1132 0
26 October 2012
Siemens introduced a new universal controller RWF5, designed to control the temperature and pressure in the gas and oil heating systems, and is to replace the model RWF40.
The controller is supplied complete with a housing for flush panel mounting. The RWF40 is matched to the controller variable and the required setpoint range by making parameter settings.
The control parameters can be set and optimized while the burner is running.
Controller with
- Three-position output
- Housing
- Fixing material and seal
Technical data
Main voltage 100-240V AC
Mains Frequency 50-60 Hz
Safety Class || to DIN 0631
Power Consumption APPROX. 8 VA
Safety Extra Low Voltage 24V DC
Temperature Range -40 to 70°C (Transport)
Temperature Range -20 to 50°C (Operation)
