New Vents ТТ PRO series
509 0
01 August 2012
The company Vents has developed an innovative fan casing design and updated the product line of the duct fans. The VENTS TT and VENTS TT PRO fans are featured with wide capabilities and high performance of axial and centrifugal fans and are specifically designed for supply and exhaust ventilation of premises requiring high pressure, powerful air flow and low noise level.
The fans are compatible with round air ducts from Ø 100 to 315 mm. Exhaust ventilation systems based on the TT fans are the best solution for ventilation of bathrooms and kitchens and other humid premises as well for ventilation of flats, cottages, shops, cafes, etc.
Design
The fan casing is made of high quality and durable materials: ABS plastic for the VENTS TT series or low-flammable polypropylene for the VENTS TT PRO series.
The removable impeller and motor block with a terminal box is fixed to the casing assembled with the spigots by means of special clamps with latches.
