New generation of Baxi condensing boilers
554 0
02 October 2012
The supplies of a new generation of Baxi condensing boilers: LUNA Duo-tec, NUVOLA Duo-tec and LUNA Duo-tec MP have been started in Russia.
Boiler Series LUNA Duo-tec can be adapted to the type and quality of the gas, flue and other conditions. All models are equipped with an integrated two-speed pump, which is electronically controlled boiler and heating system adjusts for optimal temperature control and energy savings. Series boilers LUNA Duo-tec also equipped with full modern burner premix gas-air mixture, and work with the modulation factor of 1:7.
Boilers NUVOLA Duo-tec, thanks to the integrated 45-liter stainless steel boiler are perfect for the situations where a large amount of water is necessary because it can heat 385 liters of hot water for 30 minutes.
Boilers NUVOLA Duo-tec are also equipped with the modern burner with the full premix gas-air mixture, and work with the modulation factor of 1:7.
Boilers LUNA Duo-tec MP reach up to 110 kW and can be installed in a cascade of up to 16 boilers. The boilers are equipped with modern burner with the full premix gas-air mixture, and work with the modulation factor of 1:9.
