Glass design radiator Teplolux Flora
570 0
01 October 2012
The company "Special systems and technologies" introduced the glass design radiator "Teplolux Flora", a home heater which successfully combined the comfort and aesthetics.
With the modern heating technology, classic shape and a positive color palette the design-radiator "Teplolux Flora" defines a new format of the equipment for home comfort. Wall heater turned into a stylish interior solution that can be a bright accent any room. Designer radiators "Teplolux Flora" are eco heaters, they create a comfortable temperature and dry the air in the room. The presence of thermal insulation layer in the construction of the heating panel distributes heat flow and directs it toward the only man. The construction design of the heatsink ensures a regular and comfortable heat transfer. Some heat is transferred by infrared radiation, which has a positive effect on the human body. The heating element is made of tempered glass, economical energy consumption and protection class I-IP44 makes design-radiator "Teplolux Flora" safe and reliable source of comfort.
The range of designer radiators "Teplolux Flora" is 10 options for any interior: two heating panel size 60x60 cm and 60x90 cm, and five colors: green, emerald green, red, brown and black.
