Leveraging the latest technological advancements in power electronics, the VLT HVAC Basic Drive is the most compact drive in its class and with its specifications to reduce panel space requirements. Numerous built-in features reduce, and in some applications may even eliminate, the need for additional external equipment such as gateways, PI controllers and PLCs. An Automatic Energy Optimizer function reduces energy consumption by up to 15 percent, while “sleep mode” functionality can help further reduce operating costs and extend drive life. Bypass frequencies minimize operating noise, vibration and resonance issues.
![](http://www.danfoss.com/NR/rdonlyres/597707A9-122B-4054-B680-F6FC2B26CD10/0/2109_HVACBasic.jpg)
VLT HVAC Basic Drives also feature a “start up wizard” that makes drive set-up fast and simple, and easy tool access further aids fast and effective commissioning and operation. A robust single-piece enclosure provides reliable, maintenance-free operation in ambient temperatures up to 50 degrees C, with no external cooling required. A unique cooling concept provides problem-free performance, even in harsh environments, without forced air flowing over the electronics.
VLT HVAC Basic Drives are part of the Danfoss VLT Drives global HVAC support organization, with local service available globally.
