In December 2011 company VESTA started sales of Comisa bottom radiator connection unit (Italy).
![](http://st-avers.ru/goods/d9e412b273c9e5e79713bf2e9cdbb377.jpg)
The unit is designed for installation of steel panel radiators with bottom connections to simplify installation and continued operation of the heating device. The unit is equipped with built-in ball valve (flow and return), you can use completely disconnect the heater from the heating system, or, if necessary, dismantle it.
