Universal Fonterra Base system
712 0
16 August 2011
Viega presents an effective system for the surface temperature regulation Fonterra Base.
The new product makes the installation process easer: the panel systems Fonterra Base 12/15 and Fonterra Base 15/17 are optimized for two Fonterra Base pipe sizes for installing universality.
Viega Fonterra Base is suitable both for the new buildings and for the reconstruction of existing buildings.
Depending on the system necessary power the Fonterra Base underfloor pipe installation can be fulfilled  with a different step and different diameters from 12 mm x 1,3 till 17 x 2,0 mm.
Panel system fixing holders are designed for the reliable fixing of pipes with the inner diameter 12 and 15 mm or outside 15 mm and 17 mm.
