Company Lufberg presents high quality fan heaters HELIOS, which are ideal for heating buildings with large open areas. They could successfully cope with the heat losses through the outer walls of the building.
Lufberg has started manufacturing
fan heaters HELIOS painted in RAL colours according to the by the customer's choice.
New design with modern aerodynamics for optimum air flow
Improved acoustic quality
Protection Rating IP44
Maximum water temperature +130ºC
Heat exchanger is equipped with an air-purge valve
Mounting brackets included
Delivery time is about 30 days (to be specified when ordering). Minimum order quantity - 5 pcs.
