Heat generators EURONORD could successfully replace traditional water heating systems at industrial facilities.
An essential obstacle for the wide spread of this kind of equipment is a necessity of individual parameter calculation of each device and its individual manufacturing at a plant personally for each case. It is attributed to a great air line system resistance variety. The static pressure should be measured each time in a wide range by the chosen power.
Such scheme stipulates additional turm of deliver from two to three months depending on the manufacturer and origin country.
Company specialists worked out a new in essence product range which allows to reduce the term of delivery to one or two weeks.
This product family includes EURONORD heat generators S series with the capacity from 100 to 340 kW and static pressure 100-350 Pa.
Technoclimate company possesses all equipment range with a preset middle static pressure at the warehouse.
The static pressure for the customer's needs could be regulated by a Technoclimate service center employee according to the calculation which is being made by a designer.
The adjustment and testing process takes 1-3 days depending on the device power and required static pressure.
In this way the customer could enjoy a totally adjusted heat generator EURONORD with individual regulations within 1-2 weeks after the order.
