The models provided a combined air cleaning system: formaldehyde filter that removes odors and harmful substances (formaldehyde, phenol, benzene) and also a filter with silver ions, destroying the bacteria.
Split systems are equipped with Neola auto restart and save the settings. In the event of interruptions in power supply unit by yourself when you turn back to previous settings.
It also provides the function of refrigerant leak detection. In the event of refrigerant leak detection sensors located in the outdoor unit, the information display of the indoor unit lights up the signal.
Comfort sleep mode sets the optimum temperature at night, increasing by 1°C during cooling, or decreasing by 1 °C in air heating mode.
If you activate the air conditioner is capable of peak performance in a short time to cool the air in the room.
Air conditioners Midea Neola have a wide temperature range performance. Neinvertornye models can be used for cooling when the outdoor temperature from 18 to 43°C, the heating - from -7 to 24°C; inverter - cooling from 0°C to +50°C, the heating - from -15 to 34°C.
