Product line includes KORADO RADIK KLASIK, VKU, PLAN KLASIK, PLAN VK и PLAN VKL series.
The panel is produced from two pressed shells of sheet steel, which are welded to the vertical channels with spot welds and around the perimeter with seam welds. Cold-rolled sheet steel with a low carbon content is used, which corresponds to FePO1 class according to EN 10130 and EN 10131.
The additional convector fins are shaped from sheet steel and is spot welded to the vertical channels of the panel on the air side. This arrangement has a very beneficial effect on the natural flow of air around the area of the radiator.
