Belimo New Generation Globe Valves
1306 0
15:48 04 February 2013
Coming in February- New Generation Globe Valves and Retrofit Linkages. New generation actuators give globe valves the “extra muscle” they need for applications where higher close-off pressures are required. The actuators offer greater force (up to 1011 lbf) with a reinforced rugged design, a selectable fail-safe position switch and a quick connect coupler, making installation quick and easy. With a retrofit linkage that adjusts to most globe valves, this actuator provides increased flexibility with reduced inventory.
