![](/userfiles/Image/trubu_polimernue_ot_proizvoditelya_.jpg)
This kind of pipes do not suffer from breaks and twists, the inner pipe section does not accumulate dirt and mud.
The plastic pipe is a perfect dielectric and does not conduct circulating current and static electricity.
The Compipe PE-Xb pipe has other advantages like high economy drade and universality. For its installation the minimum quantity of fittings with wringing out profiles H, TH, B is required.
The 'Aquatoria Tepla' Engendering Center is beginning Compipe PE-Xb sells this June.
