Steel Panel Radiators Korado Clean
1205 0
29 November 2012
The Korado CLEAN model is a steel panel radiator in the KLASIK version, which allows for left or right side connection to the heating system distribution mains. It is designed for pressurised heating systems or those with gravity circulation. It has been modified for installation and operation in rooms with greater demands on hygiene and cleanliness. All types are supplied without additional surfaces, grilles and side covers. Two upper and two lower fixing hangers are welded to the back,radiators 1800 mm in length or longer have six fixing hangers welded to the back. Basic equipment includes an air vent and blanking plug and the required number of type 18/120 drill-in brackets, which allow for fixing of the radiator in a standard manner at a distance of up to 65 from the wall.
