The GB162 is capable of achieving efficiencies of up to 96%. This is due, in part, to its patented, extremely efficient, aluminum silicate ALU-Plus heat exchanger, but also because our advanced Energy Management System encourages the GB162 to remain in condensing mode.
Condensing technology has long been used in Europe. By condensing the water vapor in the flue gases into liquid water, the maximum amount of heat from the fuel is captured.
The condensing efficiencies of the GB162 can also be combined with the benefits of a cascading system to ensure you receive every possible bit of energy from the fuel you are burning.
![](http://eco-complect.ru/sites/default/files/images/logamax-plus-gb162-100-kvt-709-b.jpg)
Advantages at a Glance
Designed for Stand-Alone or Cascades
Ultra-High Efficiencies
Ideal for Smaller Commercial Buildings and Large Residences
Unique Manifold for Easy Installation of Single Units or Cascades
Innovative ALU-plus Condensing Heat Exchanger for Long Life and Easy Servicing
Modulation Ranging from 20% to 100%
Cascades up to 400kW (4 boiler max)
Technology
Compact Dimension, Light Weight, High Output Ø Innovative ALU Plus condensing heat exchanger for the longest possible life and easy servicing
Efficiency of up to 93.9% AFUE
Modulation down to 20% of total output for year round efficiency
Compact and lightweight
Cascades up to 4 units
Quick-Install: innovative cascade concept for easy installation
Ideal for smaller commercial buildings and large domestic properties
Whisper quiet
Low flue gas emissions
LPG conversion kit available
