New outdoor unit Kentatsu
434 0
16 February 2012
The company Kentatsu has expanded the range of multi-split outdoor unit with a new outdoor unit K5MRC100HZAN1 designed to connect up to five indoor units.
Quiet and efficient operation of an air conditioner is provided by DC-inverter compressor motor. Output power is 10,5 kW.
The device uses ozone-safe refrigerant R410A. The possible maximum length of the pipeline is 60 m. The outdoor unit can operate successfully at temperatures from 0 to +50°C (cooling) and -15 to +24°C (heating). Despite the fact that the multisystem indoor units are able to work simultaneously in only one thermal mode (cooling or heating), it is possible to set individual temperature parameters in each room.
