Daikin Altherma
501 0
29 May 2012
The new Daikin Altherma low temperature heat pump is an innovative solution designed to deliver only the best in climate control. Ideal for thermally efficient or new homes, Daikin Altherma low temperature split can be configured flexibly with under floor heating, low temperature radiators and fan coil units. So you can create a versatile yet low energy heating system, with smart room temperature management and intuitive controls.
Daikin Altherma low temperature heat pump provides the highest savings on running costs, by achieving the very best seasonal efficiencies available within the temperature range required.
Daikin Altherma low temperature split really is the low temperature heat pump to suit all climates. The compact outdoor unit is built to withstand severe winter conditions and is easy to install and service, with all hydraulic parts contained within the indoor unit.
Daikin Altherma low temperature split is the perfect choice for new builds and low-energy houses. A custom-made solution for very low heat loads, it delivers heating, cooling and domestic hot water all from one system, yet is built to withstand the most severe winter conditions.
The integrated indoor unit offers the best domestic hot water solution, and requires a very small installation footprint within the home. For minimum electrical input, it delivers a constant supply of domestic hot water.
