New RIDGID water jetting machines
702 0
26 March 2012
RIDGID water jetting machines are designed to clear sludge, soap and grease blockages in drains. As the hose is pulled back the unit power washes the line flushing debris away.
The new KJ-3100 water jetter is the latest addition to the RIDGID® drain cleaning line, now replacing model KJ-3000 that has become obsolete.
Providing more flow and more power for efficient cleaning of lines, the KJ-3100 jetter helps users to restore drain lines to their full free-floating capacity without using harmful chemicals.
A professional high quality solution at a very competitive price, this is all possible with RIDGID® KJ-3100 water jetter.
FEATURES AND BENEFITS
Improved Performance: 30% more water flow due to a 16 HP recoil start gasoline engine. With an actual working pressure of 205 bars and flow of 21l/min, drains can be now cleaned more easily and more efficiently.
Lightweight Hose: the hose with nylon braid provides significant weight reduction and increased flexibility, without affecting its strength.
Increased Portability and Maneuverability: due to the practical 58 cm wide two-wheeled cart, the water jetter will easily fit through standard size doors and tight turns.
Pulse action: the pulsing action of the jetter stream allows the cleaning head and hose to easily and quickly maneuver through traps and bends in the line.
Quick start-up: 16 HP Recoil start gasoline engine starts easily. Features: ON/OFF switch, fuel shut-off, choke and throttle controls. Easy access oil fill and dip stick.
