The company "Egoplast" presented the new metal polypropylene pipe Pro Aqua Duo. The pipes favorably differ from the analogs due to the ease of installation and durability. The pipes Pro Aqua Duo have benefits of both metal and polypropylene. Thus the reinforced aluminum layer protects from the penetration of oxygen into the system and reduces the linear pipeline elongation, it makes the system durable. As a result, it is possible to increase the distance between the supports by the system installation, as well as to reduce significantly the number of joints. In addition, the central location of the aluminum layer facilitates the installation, since there is no need to smooth the pipe out. It is necessary only to part-off the pipe.
The main advantages of pipes Pro Aqua Duo:
- Easy installation;
- Durability;
- The linear expansion coefficient is less in 5 times compared with non-reinforced polypropylene pipes.
- Reduced cost of installation due to the decreasing in the number of necessary supports and the exception of the smoothing-out operation.
Pro Aqua Duo pipes
- 11 August 2023 Новое видео уже на YouTube-канале PRO AQUA
- 9 August 2023 Поршневой редуктор давления PRO AQUA с новой конструкцией
- 24 July 2023 Новинка в ассортименте аксиальных фитингов PRO AQUA: адаптер 3/4‘‘ «евроконус - плоскость»
- 6 June 2023 Гофрированные трубы PROKAN и PRODREN под брендом PRO AQUA
- 18 May 2023 Новая линейка хомутов PRO AQUA PROFIX
- 16 May 2023 Продукция PRO AQUA в новом видеоролике блогера «Добродушный сантехник»
- 17 April 2023 Продукция PRO AQUA в новом видео у блогера Mary Wood
- 11 April 2023 Современные решения PRO AQUA для систем отопления и водоснабжения
- 21 February 2023 Рейтинг шаровых кранов PRO AQUA
- 15 February 2023 Компания PRO AQUA представила шаровой кран с новой конструкцией
- Тэги:
- Бренд Эгопласт
- Piping systems
