The company Arctic presents the new product, a constant air flow valves CVD manufactured by Polar Bear.
Constant air flow valves CVD are intended for use in ventilation and conditioning systems for various purposes, when you need to ensure a constant flow of air in some parts of the ventilation system, regardless of changes in operating parameters of the system. The valves are installed inside the CVD circular ducts, and ensure the maintenance of a constant air flow over a wide pressure range from 50 to 200 Pas.
Application of CVD valves can significantly save labor costs for commissioning, providing fast and precise balancing of ventilation systems.
The operating principle of the valve is based on the change of its aerodynamic pressure change in the ventilation system: the sensor element (spring-loaded flap) increases or decreases the flow section area to compensate the altered pressure in the system, and this way provides a constant flow rate.
Structurally, the valves CVD consist of thecase equipped with a rubber seal, which is placed inside the flap, based on a calibrated stainless steel spring, and a set of additional removable plastic inserts. Each CVD valve has from three to five pre-set operating values of air flow, the valve setting for a specific circumstances is made by varying of the number of removable inserts.
Власти Австралии одобрили проект энергомоста в Сингапур мощностью 1,75 ГВт Энергомост заработает в начале 2030-х годов ...
В Китае запустят первый в мире двухбашенный гелиоконцентратор на 30 000 умных зеркал Проект запустят к концу года ...
Солнечные батареи защитили от выгорания при помощи особых молекул Авторы разработки использовали самособирающийся защитный монослой ...
На Сахалине начали производство зеленого водорода Запущен в работу первый в России водородный полигон ...
В Китае установили самый мощный в мире прибрежный ветрогенератор Ветрогенератор будет производить 72 гигаватта чистой энергии в год ...
Бразилия стала лидером G20 по доле ВИЭ в структуре электрогенерации В среднем по G20 этот показатель составил 29%, согласно данным Ember ...
Объем рынка плавательных бассейнов вырастет на 7,43 млрд долларов США в период с 2024 по 2028 год Повышенный спрос на бассейны ...
К 2030 году рынок промышленных тепловых насосов принесет 15,86 миллиардов долларов США Среднегодовой темп роста 7,8% ...
Изменились требования к тепловой защите зданий Минстрой РФ опубликовал обновленный СП 50.13330.2024 «СНиП 23-02-2003 Тепловая защита зданий». ...
Скоро состоится «BAXI Expo и Партнёры» — выставка для специалистов в области ОВК! 25 июля в Тюмени пройдёт выставка-конференция «BAXI Expo и Партнёры» ...
Китай намерен построить в Таджикистане солнечную электростанцию В стране более 200 дней высокая интенсивность солнечного сияния ...
Mingyang создал двухроторную V-образную платформу плавучих ветряных турбин Официальный запуск платформы плавучих ветряных турбин OceanX ...
Tesla поможет Китаю увеличить вычислительные мощности страны на 30% к 2025 году Передовая технология хранения энергии Tesla Megapack ...
Ученые доказали рентабельность производства водорода из энергии морского ветра Прямо на станции морского ветра ...
В США испытают японскую технологию компактных вертикальных ветровых турбин Ее уникальность — в двух винтах, насаженных на одну ось ...
Электростатическое отталкивание набирает популярность в очистке солнечных панелей Инновация уже протестирована в Чили ...
Структурная батарея снизит массу автомобилей и самолетов на 50% Инновационный материал на основе графитовых нитей ...
Ученые открыли четыре новых анаммокс-бактерии для биоочистки воды Уникальные свойства бактерий будут применять для промышленных нужд ...
Корпорация Amazon перешла на 100% ВИЭ на семь лет раньше запланированного срока Amazon инвестировала «миллиарды долларов» в более чем 500 проектов ...
АО «СиСофт Девелопмент» сообщает о выпуске новой версии цифровой платформы Для управления жизненным циклом продукции – TechnologiCS 8.0 ...
Московские ученые «соткали» сверхтонкий материал для энергоемких аккумуляторов На разработку получено несколько патентов ...
В Петербурге разработали компактную батарею с «электрическими» бактериями внутри Ученые ищут индустриальных партнеров ...
Индонезия планирует применять водород на электростанциях мощностью 41 ГВт Водород является одним из решений по сокращению выбросов углерода ...
Ударные волны солнечного ветра способны повреждать электросети на Земле Опубликованы результаты наблюдений ученых из США ...
Прорывной электролит снижает стоимость твердотельных батарей на 90% Новая разработка специалистов Научно-технического университета Китая ...
WoodMac прогнозирует 3,8 ТВт новых солнечных электростанций к 2033 году Совокупная установленная мощность СЭС в мире увеличится почти в 4 раза ...
В МЭИ разработали систему управления водно-химическим режимом энергообъектов Она позволит повысить надежность оборудования и снизить затраты ...
Конференция «CSeзд промышленников и строителей» прошла в Москве При информационной поддержке журнала СОК ...
25 июля в Тюмени состоится выставка «BAXI Expo и Партнёры» Компания «БДР Термия Рус» проводит выставку-конференцию в Тюмени ...
Подписка на новости отрасли
- 24.07.2024 10:00 - 13:00 Seminar Завтрак с производителями «Shinhoo», «VandJord» и «Tecofi»
- 24.07.2024 11:00 - 12:00 Webinar Кондиционеры Hisense. Обзор ассортимента.
- 25.07.2024 09:30 - 13:00 Seminar Лунда: Завтрак с производителями «Henco» и «Stahlmann»
- 25.07.2024 09:45 - 17:00 Seminar Семинар по продукции ROMMER
- 25.07.2024 10:00 - 17:00 Seminar «День монтажника» LUNDA в Воронеже
- 25.07.2024 10:00 - 13:00 Seminar Лунда: Завтрак с поставщиком «ENGO Controls»
