‘15 class’ units allow the optimum selection of indoor units in applications with small heating and cooling loads per room such as well-insulated or smaller areas. It will also be possible to connect more indoor units to a single outdoor unit.
![](http://d2gzmlqnkfjqmm.cloudfront.net/data/product/content/agg/mcquay/Daikin-Industries/11000/E515E559E82E33DC32694B283450B22C_VRVIII.detail.jpg)
Concealed ceiling units FXDQ-P7 are new devices of this year. Compact dimensions make it easily possible to mount them in a ceiling void of only 240mm.
The unit blends unobtrusively with any interior décor: only the suction and discharge grilles are visible. Medium external static pressure facilitates unit use with flexible ducts of varying lengths. Standard air filter removes airborne dust particles to ensure a steady supply of clean air. The units have standard drain pump with 750mm lift. For multi tenant applications an optional PCB is required. Noise level of a FXDQ15P7 unit makes 27 dBA, air flow is up to 450 m3/h.
