DanVex H-150 Waste oil Heater
BTU Input - 147 kW per hour
Fuel Flow Rate - 13.6 liters/hour
Air Flow - 7000 m3
Heat Rise Over Input Air - 120°C maximum
Exhaust Flue Diameter - 25 cm diameter available
System Dimensions - 185 cm H x 125 cm W x 75 cm D
Shipping Weight - 455 kg
Commonly Used Fuels
- Used crankcase oils, ATF, No. 2 fuel oil, up to 90 weight gear oil and diesel fuel
