Ariston at Ecobuild 2012
603 0
18 April 2012
Ariston was showcasing its extensive range of highly efficient domestic boilers and cylinders at Ecobuild 2012, plus unveiling two new products; NEXT SFT, an instantaneous gas fired multipoint water heater and NUOS, an unvented cylinder with integrated air source heat pump. Visitors to the Ariston stand - N2725, Excel, London - will also have an opportunity to view and enquire about the current range of Ariston products.
On display for the first time will be the innovative NUOS FS200 air source heat pump water heater. Using a thermodynamic cycle to heat domestic hot water quickly and proficiently, NUOS has been designed as an energy efficient alternative to traditional (electric storage) water heaters. With a CoP of 3.7, the unit is capable of raising the water temperature to 55°C with just the heat pump (a backup immersion is present to bring the temperature to 65°C) making it an ideal solution for off gas properties or as a replacement for existing electric only cylinders. The NUOS features an intelligent control system that allows the user to set the time hot water is delivered. The product will then intelligently determine when to start heating the water in order to achieve the desired temperature at the required time.
Also, previewing at Ecobuild 2012 is Ariston’s new instantaneous gas-fired water heater NEXT SFT. The multipoint unit has an output of 25kW in order to supply dwellings that include a kitchen and one or two bathrooms with domestic hot water. Designed with comfort in mind, NEXT SFT features thermostatic controls to ensure a stable temperature is maintained, regardless of water usage variation. The unit also features an enlarged LCD display and remote control for ease of use.
Ariston will also be offering a preview of the upcoming improvements to their E-COMBI and current boiler ranges as well as a new range of control options.
Experienced members of the technical team will also be on hand to discuss Ariston’s Solar thermal product offering as well as the high quality, stainless steel, floor standing Aquabravo range of cylinders, comprising direct, indirect and twin-coil with capacities from 80 to 305 litres.
Mustafa Findik, Managing Director, Ariston UK commented: “We have an excellent range of boilers and cylinders, plus the very latest in renewable energy products - both in terms of technology, and quality. Nothing beats seeing products at close quarters, so Ecobuild 2012 will give our customers and installers the chance to examine them first hand and the opportunity to ask our highly trained staff any technical questions.”
