Ariston Egis Plus
660 0
10 October 2011
In September 2011 Ariston Thermo Group starts selling wall hanging boilers Egis Plus 24CF/24FF. It is an economy class equipment for retail. The boilers Egis Plus have separate heat exchangers and an LCD display. 24СF type has an open combustion chamber, 24FF type has a closed combustion chamber.
The boilers are adapted to Russian operation conditions, they could operate with lower gas pressure (min. 5 mbar), low water pressure and flow rate, show stable results by change of voltage.
Heat power could be reduced, at the same time the hot water supply capacity is left unchanged.
There are following functions: turning on delay, continuous electronic flame modulation, freezing protection,  scale protection, circulation pump and 3-way valve blocking protection. The boilers are equipped with self-diagnostics system, automatic adjustment mode (combustion analysis and setting of minimal and maximal capacity at the gas valve).
The main spiral heat exchanger of the boiler is made of copper with a protective covering, the secondary plate heat exchanger for domestic hot water is made of stainless steel.
The burner has a protection against often turning on/off and is made of stainless steel as well. Hydraulic unit is made of composite, three way valve is motorized. The boiler has two NTC sensors, two wire mesh filters, 8 l expansion vessels. Room thermostat or digital programmable thermostat T-Control are available. There is a two-year warranty on the boilers Ariston Egis Plus 24CF/24FF..
